The kid who built the car put a z32 fuel filter and a z32 fuel pump with stock injectors and a z32 maf as well as a safc 2. The ECU was "supposedly" rom tuned but who knows if thats true. The setup he has now is a T04e turbo with a 38mm external waste gate that supposedly has a 16 psi spring but I watched the boost jump past 20 more than once so who knows at this point what spring is in it. I plan on using the car for a run around- weekend at the track car so it has to stay reliable. Whats your guys thoughts on what fuel system upgrades if any that i need to make? As far as engine management Im not much of a fan of safc's so Im going to be looking into getting Nistune asap. Any advice is greatly appreciated! Also are the t04e turbos know to be laggy on a stock rb? Thanks again every one.
