just bought a 78' 280z
A home for 1983–1989 300ZX owners!
mjw78_280z
Car: 1978 280z
I bought a 1978 280z as a project car. Since purchasing it we have been able to get it started a couple of times but only while working the throttle.I have not had much luck lately, the car will turn over but it just wont start. It seems like the fuel, vacuum, is good. I think the problem is the injectors are not firing, although I cant confirm this. There is also a relay (electronic fuel injection relay) its not energizing. Havent traced the power to that yet. That may have something to do with it. My knowledge of cars is pretty limited. Any help or ideas would be appreciated. Greg
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Welcome to NICO! I have a 78 280Z myself as well
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
are you getting fuel pressure? the afm can stick and shut the fuel pump off, easy enough to stick you finger in there and move it, beyond that the injecotr relay on the 78 I believe is located above the ecu in the drivers kickpanle (it's been a while since I've played with stock electronic's), the injector connectors are a common problem they crack and stop making contact, does it fire up better with a shop of starting fluid? just want to be sure we're looking in the right direction
oneway
Car: 76 280Z L28ET swap w/5-speed, 82 280ZX Turbo, 77 280Z, 90 300ZX
just to add to the above.... check the wires going to the battery, there is 2 10 gauge wires, along with the big cables, the 10 gauge wires should be one on each post. When I bought my car the battery had been replaced and both wires were put back on the positive side, so the computer (and fuel relay) weren't getting power.(ground)
Stealth-Z
Car: 1991 300ZX
Right click and save this file. It is the theory and troubleshooting manual for the fuel injection system. http://www.fairladyzg.com/PDF/...k.pdf
oneway
Stealth-Z wrote:Right click and save this file. It is the theory and troubleshooting manual for the fuel injection system. http://www.fairladyzg.com/PDF/...k.pdf
The Z bible
mjw78_280z
Car: 1978 280z
Thanks for the manual that will help a bunch! Have a good one!
mjw78_280z
Car: 1978 280z
Thank You for the input, I really appreciate it! Have a good one.
mjw78_280z
Car: 1978 280z
Thanks, the manual really helps!
Return to “300ZX (Z31) Forum”
