fireslave »
https://forums.nicoclub.com/fireslave-u106426.html
Mon Jan 26, 2009 7:53 pm
So I got a 92 coupe, finally. Other than the fact that alot of little things are broken, its pretty sweet.
The headlights were stuck up when i purchased the car. I can crank them down manually, and they will pop up, but only if i flash the high beam or press the headlight button. turning on the low beams does not make them pop up.
I removed all 3 relays by the air filter, i figured switching them might help me out in some say (atleast figure out what was wrong) but to my surprise, the lack of the relays has no effect... the headlights still pop up with either the button or the high beams.
The box by the air filter has the other relay, which i removed, and not surprisingly, they didnt move at all with no relays.
I think this car has been modified (well, i know it has, but specifically the headlights) theres a small potentiometer looking dial mounted by the passenger side relay box... looks pretty non-stock, but maybe i am dumb. (kinda looks like the a pivot controller, but its not dressed up or anything)
The motors run strong when they pop-up the lights, so its not that. I first though that the shaft that connects the light to the motor was causing binding at the up position because it was set too long, but I adjusted it to the proper height, and the motor can be spun freely with the knobs pretty easily now.
I was surprised that the headlights would even raise with only one of the relays in place, but i've never dealt with pop-ups before.
Could it just be that I have some bad relays by the airbox? what relays need to work to lower the headlights?
I did a search, but i have yet to find out what exactly each relay does, or what pins in the relay box I can stab with my multimeter to find out where the problem is...
Man, It's good to finally have a 240...
