The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Mon Jul 21, 2014 2:56 am
Pretty sure the voltage should stay up with the alternator running. Definitely less expensive to replace the alternator than the ICC stuff, and could solve both problems. I'd replace the battery first just because of the odd things I've seen with weak batteries in these cars. For instance, I wouldn't be surprised to find that a weak battery caused an ICC DTC to trip, and I certainly wouldn't be surprised to find that a weak battery put enough additional load on the alternator that it couldn't keep up with everything else running too.
ETA: Also, I think your battery should show 13.1V when the car is off, so 12.2V is almost low enough to indicate a bad cell in the battery, which would be even more likely to cause problems than just having one that doesn't hold a charge well.
