es.biggs wrote:120k kit - number one priority
New spark plugs - NAs take NGK PFR6B-11, and do NOT use any other plug. This car is very picky about that. It runs great with these NGK plugs and these plugs only. I can't remember which plug the TT takes. Are you NA or TT?
New fuel lines
Set timing with CAS and timing light
Check electrical connections for corrosion and clean if necessary
All these topics have been covered before on here, so go ahead and search em up! Great place to get parts is
http://www.importpartpro.com
Stock and slightly modified TTs take the PFR6B-11B.
The 120K kit is a must do, with no maintenance records. If the timing belt goes on the VG engine, you're in a world of hurt. Biggs is right, IPP is the best place for OEM and many performance parts:
New fuel hoses and filter
Fresh oil change with Nissan filter or pretty much anything but Fram
Set timing as noted above
Also run the ECU diagnostics to find out if there are any codes (not all codes trip the CEL)
Tech articles can be found here in this forum at the top in the sticky format, and on twinturbo.net as well in their FAQ and Tech pages.
