just bought a 1990 240 and have a problem
devildog240
Car: 1990 nissan 240sx
ok so i bought a 1990 240 for $500 the only prob was the dude that had the car b4 me broke the key in the ingnition in the off position and the steering wheel locked dont wanna pay uber dollars to have some dbag mechanic do sumthin stupid and tell me that its gonna cost 3-400 dollars please help
twichel04
Car: 1989 240sx
if the key is in there, you should be able to turn, unless its not the right key...which would explain how the po broke it off. i had a key broken off in a door once, i just used a bit of super duper super glue on the tip of a flat head screwdriver. just held it there till i was sure it was dry. then slowly and carefully pull the key out.
Nissan Junky
Car: 90 s13
Just go and buy another ignition that comes with the key and put it in .If you go to rock auto i think they have them plus they cheaper then other places.
safin
welcome to nicothats an easy fixgood luck
devildog240
how do i fix it
CSLAVE
Car: 1990 Toyota Celica STX
twichel04 wrote:if the key is in there, you should be able to turn, unless its not the right key...which would explain how the po broke it off. i had a key broken off in a door once, i just used a bit of super duper super glue on the tip of a flat head screwdriver. just held it there till i was sure it was dry. then slowly and carefully pull the key out.
OR
Nissan Junky wrote:Just go and buy another ignition that comes with the key and put it in .If you go to rock auto i think they have them plus they cheaper then other places.
Gabes13
Car: rb20det s13
safin wrote:welcome to nicothats an easy fixgood luck
rofl
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
super glue and a toothpick.
