just bought '91 SE-R, $200 buks!
drunkclever
Car: 91 sentra se-r
Just like the title says, I just bought a '91 sentra SE-R, and it cost me 200 buks. Its black and has g20t leather rear seats. The engine is good but the transmission might be bad, I am not sure. It seems to be stuck on 2nd gear. I was told the clutch is newish and has less than 500 miles on it. Depressing the clutch and kicking the lever doesn't work(FACT).
I am guessing that I can transplant a bigger engine or even something with a turbo.. but what? I was told the trannys are real cheap and can not handle the dump of a high hp engine. Can someone give me a hint of what I can do to this car that can make it outrun other popular cars?
thanks,drunkclever
nametakennow
Car: '06 MINI Cooper S
There's an FAQ about what motors swap easily into that car. Be more specific about your goals (say hp and/or cars you want to be comparable to) and we might be of more help.
The trannies are fine, they'll handle 250-300whp without too much trouble. For more than that, it's recommended that you get a 2000-2001 Sentra SE performance package transmission. If the transmission needs replacing anyway, you might as well make the upgrade to the later one.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
If the clutch is new, I would say something is wrong with the T.O.B. I would give that a whirl before finding a transmission. If there is nothing wrong with the motor, then keep driving it like it is until there is a reason to dump money into a something different. DET is the only route to go if you want to have some real fun.
skeluhtor
Car: 92 nissan sentra E
this prob doesnt help you but it might help someone... i hit a big *** bump while shifting one day and something happend i wasnt sure what at the time but i was stuck in 1st gear, after messing around for a while i realized my rear transmission/motor mount broke and some bolts broke from transmission to motor so my engine was sitting cocked backwards holding it in 1st, i figured this out by jacking up the back of the engine and then trying to shift..... but urs is 2nd gear maybe ur front mount broke ???????
