Just bought '82 720 - rear brakes
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
jckevin
Car: 1982 Datsun 720
New to the forum. Just bought a 1982 720. It needs brakes in the rear for sure.
Can someone do me a solid and tell me exactly which brakes to order? I can probably figure out the rear shoes/pads... but what about replacement drums?
Rock Auto has the parts I think. It's just a wee bit confusing. Would love a recommendation so I can just pick the parts up ASAP.
Kevin
Without knowing if it's 2wd or 4wd, there's no way. Just look your rig up on RA. You shouldn't need replacement drums unless yours are thin. Rear braking is a fraction of front braking, so I'd replace shoes and make sure everything else is lubed and clean while you're in there.
jckevin
Whoops. Right. It's 2WD.
EBrake isn't working / needs adjustment too. I'm really excited to have this thing.
Easy enough to look up on RA.
Also, have you pulled the service manual yet? That'll help a ton, esp if you haven't worked on one before.
You can get it as datsunservicemanual.com
Return to “Datsun 720”
