95NA300ZX »
https://forums.nicoclub.com/95na300zx-u124018.html
Sun Jul 04, 2010 11:29 pm
I use to own a manual N/A 95 Z. My shifter felt like it was in neutral all the time until I replaced the plastic bushings. I dunno if this is correct or not, feel free to correct me if I'm wrong but you could check to see if the trans mounts are worn out or even maybe loose if the previous owner has removed the trans. When letting off the gas that causes the engine and trans to move slightly. Just a suggestion. The grinding issue could be within the synrcos. I know that the old style trans in the z32s are notorious for having grinding issues as well which is why upgrading to the newer 99 spec the the best choice! sry if this doesnt help any.
