sileightysomeday »
https://forums.nicoclub.com/sileightysomeday-u27251.html
Wed Oct 19, 2005 5:35 pm
you know, i recently replaced the turn signal stalk... because my pass. side headlight wouldn't work at all. now they don't go up and down, could it be possible that i have two defective stalks? is there a point on the stalk thati can just clean or something for a better connection? i also, replaced the gauge cluster not too long ago also. i've also replaced the TCU, and battery. hm... i'll check with my old stalk and see if it helps. i think it might just be a bad connection at some part, cuz the headlights used to come down after a while on their own, so im thinking that maybe there is a bad point, and occasionaly it will make contact and thus make the headlights go down... hm.. tinkering this weekend... thanks.
