evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed May 02, 2007 6:39 am
to get to 300 whp you are absolutely at the limit of the stok injection, I only know of one guy who managed ti on stock electronic's, and it was not streetable! to support the top end he had to ruin idle and off idle quality, the stock turbo is a T3, the usual upgrade is the T3O4E, this flows enough air to get you to nearly 400 whp, but you won't get there on a stock motor, the fuel pump, injectors, managment, HG and headbolts, all max out around 250 whp, it's really a matter of how far you want to go and how much you want to spend
my setup dyno'd 230whp with stock electronic's and no i/c at 10 psi
I added an i/c larger injectors, fuel pump, and ditched the stock managment in favor of megasquirt, and put down 265 whp at 18 psi
I then added the T3O4E 57 trim, and added a Metal HG and ARP headstuds, as I was getting pretty bad head seapage at this point, ran it this way a 14 psi, then turned it up to 20, and then started loosing compression in 2 cylinders, by the time I got to the dyno I only managed 299 whp, with a fresh bottom end it should be mid 300's, I however am building a stroker bottom end
in the persuit of HP on the turbo L6, it's advised to run a mechanical head, and a higher comperssion ratio than the stock 7.3:1 but only iss your ready to do all the other supporting mods
also note I do not run an air filter...... at all.....ever! I also have streight through exhaust, home made downpipe all mandrel bends and no muffler....at all......ever! also at this point the car isnt' what I call streetalbe, not just the lack of interior but the engine has 2 speeds, off and on! idle would be better with a mufler but not too bad, but my timing curves are pretty agressive so when it starts to spool it goes full spool quickly and this can be violent, even my new 12 wide wheels with 315 wide tires just will not hold, the rear of the car is just too light, of course if you are sane and keep your interior complete you won't have the traction issues I have
