rc1honda wrote:There are other things that will set of the CEL on the FC, such as airflow limit, and injector duty cycle. But if your reading a 91 on the knock sensot thats pretty high, it could be soemthing mimicking knock but anything over 60 is considered dangerous. Check your timing maps and turn off your injector warning and airflow warning. Also your said you were having some oil pressure issues? I know for a fact that lifter tap is almost the exact same frequncey as knock. If you losing oil pressure and you lifters can't get enough oil the hydo lifters will begin to tap , and mimic knock on the PFC and cutting your CEL on. Just a thought.
It could be a sensitivity issue. I am going to run it low boost for a while and try some different gas until I can figure it out. I never heard any pinging or anything and it did not lose power.
Thinking it is
1. Gas difference tuned on exxon super premium and currently running shell v power 93
2. picking up other things than knock
3. bad spot in the map that does not pulling timing enough
It only does it on interstate in 4th and 5th gear pulls running to 17lbs on my gt2871r
