erollinc »
https://forums.nicoclub.com/erollinc-u8459.html
Wed Jan 02, 2008 4:36 am
hey guys i recently picked up a vh45de out of a q45 for 75 bucks ( thinking somethings gotta be wrong with it, car was clean) well expecting the worst i hooked up the starter and put a lil oil in all 8 cylinders and did a compression test ... knowing it woudlnt be a legit test, i jsut wanted to see if it had compression and turned ok. sure enough ,made over 270 on all 8 cylinders. ( keep in mind this is from the oil) im assuming under normal conditions itll make 180-200
im going to take the front covers off tomorrow and make sure the timing is still good. now my questions are, why arent timing chain kits available online? is it nessecary to replace everything?(timing chain/guid/sprocket wise) can i just get the newer metal guides and call it a day? is there anything else i should definitely consider b4 i attempt to swap this into another car?
