vboyq wrote:I know this has prob. been asked but i can't seem to get a definitive answer under the Big Red Button, I also know that alot of it has to do w/ the driver but here goes: Let say i have a s14 w/ a s13 motor, intake, exhaust, downpipe, 255lph pump, z32 mafs, intercooler BOV, and boost control set at 14psi, a tuned Apexi AFC, stronger cluth and pressure plate and lightened flywheel, and SE LSD
1)U guys think there's anything missing..(Daunt, Jesse..?)and2) what can the expected 1/4 times be??
THANX AGAIN to any replies!
Brakes, and suspension.
prob run a mid 13....s14's are a little heavier (most of those 12's were semi/fully stripped interiors), but then again, open diffs, and your LSD will knock a good .2 seconds off your 60ft if your a good driver : )
Im not a fan of lightened flywheels, it may hurt your 1/4 mile to be honest...you'll have to be the judge on that one.
Relo your battery to the trunk.
Drag radials or slicks.
Tune it good : )
