some old and some new;
heres the new head and fresh pistons after i got the crank back in
old pic of engine bay (before overhaul and cleanin/painting the bay)
and the motor before it got put back in...have new picture somewhere if i cant find em then i will take some new ones 2mra
also just recently did rear control arm bushings, sway bar bushings, and lower ball joints, very responsive
here is a list of mods for those who dont know haha
Engine
2.5l turbocharged Rb25det, TopHat motor/trans mounts, Touge factory steel braided turbo lines w/ restrictor, Nissan N1 oil pump, Godspeed front mount intercooler, intake manifold, radiator, hoses, 2 12” electric fans, CX 80mm throttle body, cometic head gasket, intake manifold gasket, ARP head studs, tomei 1.5mm oil restrictor, 3 angle valve job, viton valve seals, cp 86.5mm pistons, acl main and rod bearings, Walbro fuell pump, z32 oil/fuel filter, full gasket overhaul, custom 3” exhaust, custom 3” intake, rb26 oil filter housing, NGK iridium plugs
Drivetrain
Rb25det 5 speed, driveshaft shop 1000hp steel driveshaft, ACT 6 puck HD clutch, Nissan z32 r200v differential
Footwork/chassis
Cusco Front 32way coilovers, megan racing street rear coilovers, Godspeed rear upper control arms, rear sway bar, tien tension rods, energy suspension control arm bushings/steering rack bushings
Brakes
300zx 30mm front calipers, drilled/slotted rotors, steel braided conversion lines, 03 altima drilled/slotted rear rotors, z31 rear caliper bracket, centric pads
Wheels/tires
Front and rear Ichiba 5 lug hubs, Front: enkei RPF-1 17x9(+22, 3mm spacer) dunlop 225/45/17 , Rear: enkei RPF-1 17x10(+18) falken 245/40/17
FR camber: -1.2
RR camber: -2.4
Exterior
Complete B*Magic body kit, OEM metal s13 silvia hood/fenders, Nissan triple projector silvia headlights/corners, custom molded body line, DuPont sovereign blue paint, custom pulled fenders
Interior
Custom fan switch, prosport 52mm oil pressure/boost gauges with custom pod, autometer wide band AFR gauge, 2+ layers of sound deadening, undercoated trunk, battery relocation, custom cup holder, loud a** horn
and ill try to get some interior pics, also just overwent an overhaul
pics available on request
lemme know what u think guys,
thanks in advance
