hiimjered »
https://forums.nicoclub.com/hiimjered-u98712.html
Sun Jul 20, 2008 4:26 pm
Not much of an upgrade, but I have a GPS I use regularly, and an MP3 player I use all the time, but got tired of running the plugs to the center console.
Here is a side view of the fuse block. I added the black ground wire as seen, simply an easy access point. You can just see the fuse I added for these sockets at the bottom of the pic. I added a new fuse next to the accessory fuses in the empty slot. I used a mini fuse tap (available at Pep Boys, or online) to add the circuit.
Here is a shot of the socket I added on the driver's right. It is completely behind the dash and bolted to one of the rails under there. For perspective you can see the heater outlet at the lower left of the pic.
This one is clearly the one on the far left. I just screwed the bracket into the side moulding. This one is quite convenient for my GPS (which I mount on the lower left side of the windshield.)
Anyway, this project was fairly quick and pretty easy, but adds quite a bit of convenience to my car.
