DurtyJ30 »
https://forums.nicoclub.com/durtyj30-u35133.html
Sat Dec 24, 2005 6:52 am
bump***
i was on the highway doing 120km/h and i lined up against an audi 1.8t. he looks at me and slams on his accelerator. naturally i react too. so the engine downshifts and started revving as if it was in neutral i could hear it trying to grip the gear. i let it go and i hear a bang and the car shook. i tried it again twice more and same result before giving up so that my transmission doesnt fail. it feels like the flywheel(flex plate) is slipping, maybe thats why the starter noise is happening. i tried to test the system a few minutes later ater the failure at 1/2 throttle, the car accelerates and it went to 200km/hr (125miles/hr for the usa folks ) it just took a while to get there. then i let off and let the car slow down back to 100km(60 miles/hr) then i tried testing it at full throttle andf the transmission downshifted and it grabbed the gear fine, tried it a couple of more times and it was fine. this boggles me.. is the transmission failing or is the flex plate just worn out due to high milage? i need some advice, i called around and it would be cheaper to just buy a new transmission than get a new flex plate. i can get a transmission of a jdm car for 300$ and install 100$ with the kms showing on a front clip but i need to figure this out so that i may take the next step.
i am very disapointed when the gear grips the car does bolt with alot of torque
