You wanted yes or no answer, so I didn't say much, but...It's not a good idea to mount 245 on 7 inch wide rim. You will have a huge bulge. I recommend this. Take your wheel to local tire shop such as Discount Tire and ask them to show you 245/16/50 tire. Put them together side by side and see how they'll look together. This is my set up. 17x8 +33(w/5mm spacer) and 235/40 17 tires. I didn't have to roll the fenders, so I'm pretty sure that you don't have to either. Trust me. You better run same size tires all the way around. 225/16/50 all the way around sounds much better to me, and most people will agree. Do not order tires now. Take your time and do more research. Why don't you ask for pictures in 240 gen forum. Someone might be running that set up. Good luck!S13FX wrote:Thank you very much I may go ahead and order tires .
.......because the wheels are the same size all around, right?S13FX wrote:ok so if I run a 245/45/16 I should be fine then and there shouldnt be a buldge. And why do you recomend that I run the same size all around?
If I were you, I'd run same size tires all around and use coilovers, sway bars and other suspension components to achieve the goal. No point staggering tires on same size wheels.S13FX wrote:I was planing on trying my hand a little autox/drift and some one recomended that I get the rear tire wider then the front tire for more precise controll. Im not sure if this is 100% correct but it did come from a pretty relaible source.Thanks.
