Just a Little Sr wiring issue....
zack240man
Car: s13 hatch ka24det & s13 coupe sr20det
Hey guys, I decided to help my friend wire his sr harness for his new swap. We looked at many different "how to guides" and write ups and still dont see where anyone had an issue with this... The black/yellow wire for the IACV power on the large grey plug is NOT on his 91 ka body/sub harness plug. Now since its only a power wire, I assumed it will required a 12v supply... Correct? As for right now it has been wired up to the blue/red and black/red... three wires going to one. Will this work or any ideas??? Also there was a solid pink wire on the Ka body harness that I could not find any reference on. I decided to just tape it off until the harness is installed, not sure if its important but if it is a 12v at the switch source I figured it could be used for the harness wiring (or other 12v accessories) So please!!!!!!!! Any input is appreciated. And yes I have searched and gooooooogled, nothing so far.
zack240man
bump??? No one??
S-ICHISAN
Car: 89 240SX COUPE W SR20DET...
yes this is o to do
i put a relay on all the switch wires to ecu
and ive had no problems
if u dont do the relay then just make sure u solder the connections
