JC87HB »
https://forums.nicoclub.com/jc87hb-u93674.html
Sun Feb 14, 2010 4:22 am
ok.. for this truck, you have some options.. Body lift, or suspension lift. If you are a DIYer then id go with the Suspension lift. you can go to 4x4parts.com. They are a vender for all kinds of nissan goodies! I have an 86.5 and i just cranked the torsion bars up front, but i would not recommend doing this unless you have the UCA(upper control arm) from 4x4parts. cause if you crank the torsion bars the camber will be un adjustable and the upper ball joints will be maxed out. So i would recommend going to 4x4parts and check out the "Superlift" kit for your 2wd truck! also be sure to get a new set of shocks that are longer to compensate for the lift, or you will over extend the stock shocks and you will be driving like a brick!
