elwesso wrote:1. As some of you know, my cruise control stopped working...... So i have started diagnosis, by testing the stop lamp switch and brake switch......... How do you test the switches???? The BCM is in the way, and I dont think I want to take it out (I always get a little nervous around the Qs computer components)..... I could hardly get my hands up there to unplug it, let alone get tester probes up there........
The brake switch is fine if your brake lamps work. If you're not comfortable probing the other switch, try to find which pins that switch feeds on the CC control harness. You should be able to check continuity there.
2. When I let go of the steering wheel on a normal road, it sort of shudders........ Bad steering rack, or could it be related to my shocks???
Could be any number of suspension components, badly warped rotors, or out of balance tires.
3. The power trunk stopped working..... I can open it up with the key, but I cant use the switch on door........ It makes noise like it is trying to open, but it wont open.......
Check to make sure the solenoid hasn't slipped or the cable isn't loose. I've heard of some solenoid failures on the Maxima, but not common on the Q.
elwesso wrote:2. When I let go of the steering wheel on a normal road, it sort of shudders........ Bad steering rack, or could it be related to my shocks???
elwesso wrote:if you undo the connector from the ASCD main switch (dash switch) and test a certain terminal (cant remember off hand) and the body ground, it is supposed to show up as battery voltage, and it comes with nothing
elwesso wrote:Come on!!! Someone on here has to have experienced this problem.... I checked the ASCD fuse in the passenger compartment, and it is ok..... I even switched it with a known good fuse....... This has to be something simple!!!!
