Ron240sx wrote:On my engine harness theres a little Jecs silver box. Its got two white wires connected to two orange wires on the harness. Is this this the resistor or something else? It sure looks just like the the rest of the dropping resistors minus it being a two wire connector.
No, it is not a dropping resistor. You'll need to wire one in to your existing harness or add radio shack resistors to your injector wiring.
Ron240sx wrote:So if my knock sensor connects to my ecu how am I suppose to route it through the secondary harness?
Tap into the knock sensor wiring running from the ecu and run it to your knock sensor. It's a white wire.
Ron240sx wrote:If i had the intentions to run 15psi on a T28 with a walbro 255 fuel pump, with an adjustable FPR will 550cc injectors make the cut or should I go bigger?
That's enough.
Ron240sx wrote:I think im going to be using Innovative wideband as its said to be a great wideband... any input?
It won't hurt anything to use it.
