just a double check on parts for sr20det swap.
madrift
Car: 95 240sx
im new on this and ive already checked out the search button. but i just want to make sure about this.okim planning on getting my swap from osakajdmmotors.comand wanted to know what all i "need" for the swap that dose not come w/ the kit. the swap includes:
Motor with the turbo Transmission (5sp) Uncut Wiring Harness All required Cables ECU Cam angle sensor (CAS) Complete Intake Manifold Alternator A/C Power Steering Pump All Brackets and Sensors Shiftlinkage
i know i should get a new radiator hose and prolly an electric fan,and intercooler w/ piping. but do i need a new radiator? and is their anything else i absolutley need.
180fan
Car: 89 fastback
intercooler pipinglower engine harnessside mount intercoolerbleh on the radiator if you're running a stock motorif you're going electric, then you'll need a fan controller or another fan triggerthe bracket for the smic if you're oging this routeignitorcheck over the cas for any dents or damaged plastic and so oncoil packsmake sure no dents on the oil pan
buy:new heater hoses (replace the ones under the intake manifold for sure, those will be a nightmare to replace after the motor is in)heater hoses for the firewallaiv cap for the turbo extensionbelts
