Infinitiguy19 wrote:
When I open the sun roof in the vent position the motor doent stop. Is this normal? When I open and close the sun roof fully or when I close the sun roof from the vent position the motor stops but in this case it keeps going.
This is normal.
The sunroof has a hard time opening, I can hear the motor working but the sunroof needs to be pushed back by hand so what could it be? I had to remove the map lights/sun roof control piece to close the sunroof manually stops spinning (Manually).
The rails needed to be greased and the motors clutch needed to be tightened. But always clean and re-grease the sun roof track (rails) before touching the motor.
How can i find out my Idle because the RPM gauge isnt the most accurate way to measure RPM's.
A Nissan Consult or Laptop Consult must be used.
Whats the best way to clean/flush the radiator and is this write-up correct well I can't find it but is said to refill with 70% distilled water and 30% collant and 2 botles of redline Water Wetter.
Won't the block crack in the winter?
What color should the coolant that goes into the radator be is it green, purple or yellow?
Use distilled water to flush the radiator and use a BG cleaner (Made for the cooling system) to flush the system. Repeat till the water that comes out of the lower hose or drain c*** is clear.
Use a coolant tester to see if coolant is sufficient enough to last you the winter.
Only Organic Acid Technology (OAT) coolant should be used which is green.
My seal on my sunroof is somewhat noisey when I open the sun roof is there any rubber condition of some sort to to quiet the seal?
Use Sil Glyde or clean with a dilluted rubbing alcohol.
When upgrading to z32 brakes do I have to cut the front heat sheild or can I just bend it back a little bit and will they fit around my Q45t wheels you know the ones that look like dubs?
When i upgrade to z32 brakes do I have to replace my master cylinder and e-brake components?
The heat/dust shields need to be cut or removed for the Z32 (1990-1996 300ZX) brakes to fit properly.
Sixteen inch wheels or bigger are required for the Z32 brakes to fit.
The Master Cylinder (MC) does not need to be replaced when adding Z32 brakes.
Transmision flushes on my Q were done every 2 years will that have any effect on the transmision life?
How do install a transmision tempurture sensor gauge,oil pressure and tempurature gauge?
I also live near 92Q45guy which happens to have a transmission cooler could that be used as an oil cooler?
And will it fit next to the transmission cooler or is that to many coolers in front of the radiator or could the "oil cooler" be mounted some where else?
Flushing the transmission with a BG machine/Snap on machine or by drain and refill will only add life to the transmission.
The OEM Q45 Transmission comes with a transmission temperature sensor but it may not be very accurate due to the age (Varnish). Installing a temperate probe in the pan is the way to go. The wires must be routed to the interior which maybe a pain. Other gauges must be installed in the same fashion.
Q45Tech said why to not use a Automatic Transmission (A/T) cooler as a engine oil cooler.
What is the rectanglar plug in back of the radio?
On the 91 models with out a cd changer hook up there are two plugs for the antenna on my 93 there is only one why? and are both antenna working though one plug?
I still have no idea what that rectangular plug on the back of the radio is.
I have no idea what I meant.
