junkyard parts: 5-lug, ecu, others
240DRFT
hey i recently went to the local junkyard and found a '92 hatch which im going to be getting the ps lines and resevoir for $15. But also theres an ecu from the 92 240 which is auto, and doesnt the autos ecu not have a speed govenor? will the ecu work with in 90 240 with a 95 kade and the 95's harness? last thing... are there any cars besides the s14s and 300zxs that i can get the 5-lugs, cuz there are many nissans with 5-lugs but no 240s or 300s. thanks, sorry if my wording was confusing.
frapjap
'07 Subaru Legacy
Yes, the 92's ecu will work just fine with the 95harness and motor. Also, while you're in there if you haven't gotten it yet, get the dohc tach as well so you'll have one with the engine swap. If you need help or questions with the swap, I can answer them for you. I did the swap last summer and did an extensive write up on it. Good luck!
240DRFT
there was a tach and it was $50, i was going to see if i could find one a little cheaper. they was $75 for the lower part of the intake manifold, so im looking elsewhere.
