junkyard motor build up, rb20det, 56k DIAF
DriftingisLame
Car: '91 240sx coupe, rb20det
Hey carl, I bet you've been asked this many times.. but what kind of pistons are those? How much and where do I find them?
All I could find is tomei pistons for like $1300 lol. Or custom.
SeVa-S13
Car: '05 GTO 6spd
Pretty sure he's using CP's, as I will be.Wiseco and Arias also make some I think.
Carl H
yup cp pistons, seem to work very well and hold up...got more pics and what not to come here in a short bit...
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Carl H wrote:yup cp pistons, seem to work very well and hold up...got more pics and what not to come here in a short bit...
Overbore or standard?
Carl H
mild overbore 20thou iirc...
Chaos the Xile
Car: 1974 Datsun 260Z
Sweet were all idoling for new material!!!
Shocker
Car: 89 240sxHB rb26/30
Chaos the Xile wrote:Sweet were all idoling for new material!!!
im pretty sure hes in the process of tuning his car right now...
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Updates?
Carl H
got a few new pics but have to upload them from the camera...
Carl H
a few updated pics...motor is in car and broken in, tuning is almost complete.got a few rich spots to sort out but other than that its almost there.kinda sucks but the brake master died (was leaking externaly) so i just got done replacing that...oh well only was 30$ at the junkyard when i got it.
what it looks like from the drivers seat: defi gauges (oil pressure, water temp, egt) and greddy e01/wideband
and a few exterior shots, first time the car has been washed in 6 months.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Lookin good carl, car looks nice too loving the r32 wheelz
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
This is probably a stupid question, but what are those two fittings on the back of the head and two lines that run down to the oil pan for? I know its oil related obviously.
Carl H
external drains for the head, with constant high rpm and uprated pump oil can pool in the head, so trying to help it back to the pan.
rb240det
Car: 1991 240sx Hatchback and 1994 300zx
Nice pics man! Good to see her back up and running again!
rbsileighty
Lookin good!
Might have killed the master cyl by cooking it... with the wastegate right there a heat shield might not be a bad idea.
Kansei240sx
Thats a good idea, let us know how that works out on those head return lines, let us know if you ever have ANY problems in the future or if it turns out to be not a good idea, not that im saying it isnt.
Carl H
thought about it but its but i think its the fact that the thing was 16 years old, it came off of a 1990 z32 na automatic....
RB20DETodd
I just wraped mine in heat tape, gets-er-dun
Carl H
for your enjoyment and courtesy of yellow4g63...http://www.3rdgearvtec.net/And...0Vidz/you will need the divx codec to view these, filenames explain exactly what is going on.was having problems with spark blowing out, anymore than 16psi and it would cut...time for cooler plugs and a smaller gap.
rb240det
I envy you....
lazyboi444
Car: 240sx Hatchback
Hey Carl H do you think you can do a write up for the External Oil return and for the Oil restrictors for the RB20? And is that stock exhaust manifold ?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
HKS cast manifold.
External drain:
Head - Drill, Tap, Clean, Insert fitting, route hose
Oil Pan - Repeat
lazyboi444
I mean that was obvious. But i need Fitting sizes. Thanks for answer the manifold question though. Reason i'm asking is because i want to make sure i do this the right way. So i ask for alot of detail. Thanks for the response.
Modified by lazyboi444 at 7:52 AM 6/8/2007
Coolwhip
Vendor
I believe its been covered various ways.
iirc, Carl used two -6AN lines, 90* fittings. Had the head tapped according to the thread of the fittings (the thread is all dependant on the fittings you use). Sealed. Ran -6 lines to the pan drill pan, weld on bungs. Install fittings to the lines, install lines to bungs. You'll see what I'm talking about as the progression of the pictures go.
lazyboi444
Thanks coolwhip i appreciate it. Sealed with Teflon tape...
oneruffryder42
so nice carl is my hero!
mello88
Car: s13
yah an old thread was bumped.. So what this a good build thread, I've never seen it
HKS ext wg <3
In retrospect did you have any other heat problems with the HKS mani? I'm going to be running the same one with hks ext gate and t3/t04e.
lazyboi444
You buying yours new or used? I thought they discontinued this Mani.
Coolwhip
Vendor
they did discontinued the HKS manifold.
However you can buy mine on EBAY right now... comes with an even more baller HKS wastegate 50mm baby!
LOL, Carl you know i had to
Carl H
ive not had too much of an issue with heat because of the manifold, as i drive the car the brakes do get a little mushy when i flog the car but im not sure if that is due to the wg positioning or rather the brakes being used.only thing i dont like about the hks mani is that it is a total whore to get the turbo on and off in the car, pretty much have to dissasemble it in the car to get it off the manifold...not fun but i'll be doing that this week when i put my twin entry turbine housing on the 30r...fun times ahead!
