tigwebu wrote:I need the driver side swith panel all so the rear window switch....how much?
the driver's side door window switch and the rear window switch?
I can get you the driver's side switch no problem but the rear window switch I'm thinking I should hold on to, if mine ever goes bad it could be next to impossible to replace! also both buttons were broke off it already but I'm pretty sure with a little sanding I can get regular window switch buttons to fit it...
anyway say $10 shipped for the driver's side window switch if you want.
