Q45tech wrote:Look at our own site, so many seem proud, that they are able to find and use a $50-$70 tire instead of a $120 one, they surely are not demanding that the manufactures make a $200 15" tire for them.
I couldn't agree more. It's one thing to look for a fair deal. In my opinion, it's a whole different thing to go looking for tires on the cheap. I haven't been around the auto industry as long as some of you guys, but in the last six years, I have not come across a cheap tire that performs better than an expensive tire. The beauty of the tire replacement industry is that it does not suffer from too much "brand-hype". You really do get what you pay for. Sure, some performance tires are priced very high, but I have no problem paying extra for a tire that performs better. All too often, people go looking for phat tyte rims, blow their whole budget on those rims, then try and find the cheapest tire possible. To me, this is backwards thinking.
A tire has only so much contact patch. All the torque in the world is useless if you can't transfer that turning force to the ground. By the same token, big brake kits are cool looking and perform very well...but again, if you have tires that aren't up to the job of providing maximum grip, was your money wasted on the brake upgrade?? Usually not a *waste* to upgrade brakes, as few drivers near the limits of tire adhesion on a daily basis, but there is a general principle in play....better grip costs more, but gives a greater return on your total investment in performance(brakes+tires).
There's always a compromise with tires....grip vs. mileage. Grip means superior casing construction, softer compound(expensive), which also means the tire wears faster(cost of frequent replacement=expensive). Higher mileage means harder rubber compound(less expensive), also meaning fewer replacements(again, less expensive). Most popular tire makers build excellent tires in a number of sizes that offer a good compromise of grip/mileage, as well as tires for both extremes: soft compound tires and also 700 treadwear rated tires.
