Jun Piston Kit! Hot! Hot! Hot!
Ninjamasta
Hey guys, while I was searching for Jun autoparts, I came across this!http://www.junauto.co.jp/produ...ml?enIt was just announced that JUN is going to reproduce these fine piston kits. However, it is only sold in Japan. Come check it out guys!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Totally hot, but seeing as plenty of great companies make pistons here in the states, I see absolutely no reason to drop a ton of money on those JUN deals. Cp, Arias, Weisco, all make them, and probably for hundreds less than JUN.
float_6969
If you find a Tomei 2L crank, lemme know cuz I have the flywheel you need to run it.
fluent
cosworth actually make them... guess how much it costs from either cosworth or jun
Probably the best ones you could buy for money but...
themadscientist
sleeve the snout on a CA20 crank and you will have a Tomei crank.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
when someone wins the lottery let me know, they can buy me a set =)
r34 gtr
How hard is it to sleve that bad boy? I might pick one up next time I am at the junk yard. Even if I never use it, it will look totally awesome in my bedroom next to my spare: turbo, cams, ss o2 housing, turbo timer, head unit, z32 AFM, etc.
Bwana
Car: Denali
r34 gtr wrote:Even if I never use it, it will look totally awesome in my bedroom next to my spare: turbo, cams, ss o2 housing, turbo timer, head unit, z32 AFM, etc.
You seriously have all that crap in your bedroom Tim? Holy crap...
themadscientist
RB guys sleeve their early cranks for the oil pump drive. I can't imaging the timing gear cog would be any different.
r34 gtr
Sweet!
And yes, I have all that stuff in my bedroom. Need something?
float_6969
I've thought about it. I can't find just a crank though, I'd have to buy the whole damn motor. There is one locally, but they want $600 for the damn thing.
I'm not paying $600 for a motor just to rob the crank out of it and scrap the rest of it.
Nowhere
Car: Suzuki x-90, samurai
Sooo, a 2 liter ca20 (e or de?) crank is GOLD?
There's a ca20 in the salvage yard near me.might be able to get that crank :D
themadscientist
no such thing as a CA20DE
float_6969
Not really gold. It just takes a lot of work to get it to work right, and you generally don't have any lightweight flywheel options if you go that route.
r34 gtr
It is totally sweet though.
Buddyworm
themadscientist wrote:RB guys sleeve their early cranks for the oil pump drive. I can't imaging the timing gear cog would be any different.
What exactly needs to be done to the crank? Is it just the part that timing belt cog slips on to that needs to be bigger?
**Edit: There's also a Tomei Crank/Piston set on Yahoo right now for anyone that's interested.
http://page2.auctions.yahoo.co...38110
Modified by Buddyworm at 6:35 PM 11/8/2007
float_6969
Ouch. I'll keep my $900.
zero_gripS13
Car: soon to be 95 s14 hopefully
the collar that drives the oil pump is ~7mm wide on the bad cranks it should be 16-18mm wide..
so the collar corrects that.. you have to machine the crank down then heat the collar and slip it on.. set screw is optional..
anyone got a pic of a ca crank?
