jumpy reading from TPS
LOVERboy
Car: 1997 240sx se KAT
Okay, so i hooked up the Apexi neo to my ecu and the throttle sensor is reading jumpy .... like if i hold in all the way down, it would go from 97 to 100... its jumping around ... is that normal?
Dire91
Car: 1997 Nissan 240sx SE
You spelled *economy wrong in your sig :bigthumb:
visser003
Car: 1991 Nissan 240sx Coupe
Did you forget to put a coversheet on your TPS Report?
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
mine goes from 99 to 100 on a aem ems
GmFwd
Car: 1994 Beretta sleeper
A tiny variation like chaosli has is normal, nothing is perfect.
However, yours is a little excessive. I would start by checking the ecu ground and the TPS ground. Then make sure your reference signal is steady(should be 5 volts). If thats all good, then its either a bad sensor, or theres a problem with the TPS output(where the ecu gets the signal from) wire.
Good luck.
