ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Wed Jun 14, 2006 2:32 am
well even if your engine holds boost fine, you might have a small vac leak somewhere that's causing your car to run jumpy like that during low RPM range.
I would do a leak test to see if you got any leaks. Also, check to see that your timing is ok as well.
