Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Fri Feb 17, 2006 4:45 pm
Absolutely, water could do that. Check your connections at the distributor, coil, and module for corrosion. You may want to check continuity from there to about 6 inches back, no more that about 5 ohms. You may then want to clean the connectors and pack them with dilelectric. It sounds like you are getting a bad tach signal or you have bad grounds.
