180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Nov 10, 2003 7:59 am
remember to loosen the cam bolts so all the valves will be closed. When pulling the crank pulley, inspect for cracks otherwise you'll be in the same boat as me, looking for a crank pulley although I just found one. When you're pulling, make sure you've got a pulley puller that's large enough not to fall into the hole for the crank pulley bolt as it'll shred up the threads if you're not careful. If you are to do it, get a series of washers that are just big enough to fit in the hole and not interfere with the pulling of the pulley (make sure it won't get gripped by the sides of the crank pulley) and put the crank pulley bolt in to use that to have the pulley puller push against. Just have alot of washers and you should be fine to use a pulley puller, that is if you've got one that's not big enough to not fall into the crank pulley bolt's hole. Mine was seized so I also had a hell of a time getting it off. Might want to try some wd-40 or some other penetrating grease once you've got the crank pulley bolt out and let it sit overnight. When you do get to pull it, pray to god you don't have a jacked pulley that'll break on you like mine did.
