jumped time?
xdreamz
Car: chevy and nissan,,, doing it better, building it,, makin it look right good and smooth
i didnt see anything about this prob anywhere i looked so,,
as some of you know i have a 91 S-13, with the orig ka24de in the shop my temp engine is the same with about 60k on it, its all stock, not one thing changed on it, i disassebled it about a year ago, and installed new gaskets just to be safe since ill be using this motor a while, well, last week i let a friend take it to a buddy house and anyway he got some cam gears for it, so i let him put them on,, and it wouldnt start, so i took them back off this mornin and put the stock ones back on and it runs!!
but not very good, a couple deciding things tho are, what little fuel is in it has been in there over a month, aside from the manifold downpipe and cat, there is no exaust,and it hasnt been driven for any real lenth of time for over 2 years, at most was about 8 miles after i bought the motor,
so i need to know, how can i check to see if it has jusped time on one or both cams? as i need to get it on the road soon!!(finally getting rid of that mitsu****ty, BTW no guys i never did get that 87' 300ZT, sucks too, i found out it does have upgraded turbo. runs mid13's saposedly,
well i would appreciate some tips asapmatt
xdreamz
guys, any thoughts about this subject please, i need to fix asap
AzurE
set the crankshaft pulley at 0º (tdc compression stroke), pull the valve cover and check the timing marks on the cams
xdreamz
where should they be? thx
AzurE
intake cam at about 11:00 o'clock, exhaust cam at 1:00 o'clock. all valves on #1 closed
Terry91FB
I recently had this prob rebuilding my ka24de, if your counting chain links they should be 8 apart. If your dot on the intake cam is pointed to the center of the link, then count seven across not including the one its on.
