NCYankee »
https://forums.nicoclub.com/ncyankee-u117889.html
Tue Mar 24, 2009 6:12 am
Thanks to both of you, that was helpful. Yeah mine hops over bumps, it's pretty hairy especially if the roads are a little wet.
I did pick up an entire half suspension from a salvage yard for $50, so I have undamaged pieces to compare - but the ball joint is sloppy so I can't just bolt the whole thing in - and I am trying to minimize bolt removal, they've never been out and I don't have a backup car if I break any. No part stores just stock them, you have to special order and they are not cheap. Unfortunately the salvage yard didn't give me the ones that were on it.
The shape of the RLCA is going to make measurement a little tough - S133, where was yours bent? The weak spot looks like the front attachment, it's a little skinny there.
Could a bend in the RLCA affect just toe? I am trying to visualize what effect that would have on tire positioning, it seems that moving the ball joint around would screw up camber more than toe - but I could be wrong, I really don't have a lot of experience with suspension problems and will bow to those more experienced. (Edit: I guess a bend in the front attachment of the RLCA would move the ball joint forward, and make the wheel want to pivot out - so that could cause excess neg toe.)
I did try to get it aligned, like I said the closest he could get it was about 1 degree out of spec, on the total toe. The tire wear is pretty even but very fast - last set lasted about 5k miles.
Modified by NCYankee at 9:30 AM 3/24/2009
