Postby
SuIiCiDaL »
https://forums.nicoclub.com/suiicidal-u149390.htmlSat Mar 20, 2010 10:26 am
i wanted to replace the antifreeze in my 07 g35. so i flushed it out and and wat i did was fill the tank with 50/50 antifreeze and some in the filler. when i ran it with the heater on high the thermostat started to go up. can anyone help please i love my baby!
Postby
smockers83 »
https://forums.nicoclub.com/smockers83-u49766.htmlSun Mar 21, 2010 4:56 am
If you don't bleed the system and remove the air, that air bubble travels through the system and you get the same result you experienced where the thermostat gives you a high reading.
