Years ago I bought this clunker rice burner of a car on eBay:
It had a KA24e which i proceded to burn the tires off before taking it apart...
Then I started really taking it apart and getting rid of all the rust.
Then worked on it some more.
Then mounted an RB25
I installed all the usualy swap parts, FMIC, walbro, etc.
Then I finally got it all finished running great in stock form and drove it less than 50 miles and put it away for a while while I concentrated on college. Then I got picked to be on pass time and won $2000 so i figured I would take it apart once again and do some more work to it and that is where I am now, I will show the pics of what I am currently doing.
I took the manifold to my machine shop and turned down a piece of cylinder billet to 2.5 and tig welded it into the hole and then welded the throttle body onto the front of the manifold. The piping is just mocked up there so dont mind it.
I also threw the stock exhaust manifold on the mill and bored a hole in it and welded in a steel pipe and ported it along with adding an HKS flange on it.
For some reason I forgot to the a picture of the turbo but its an HX35 that I bought used and will be getting rebuilt with this.
I also picked up a z32 ECU that I am going to have autovaugh performance install a nistune type 2 board in so that I can get this baby tuned. I have a lot more odds and ends to pick up as well as injectors so as all of this stuff comes in and I get free time to work on the car I will update.
