jr_ss »
https://forums.nicoclub.com/jr-ss-u34795.html
Sun Oct 19, 2008 3:32 pm
Alright, I'm starting a build thread... I'll update as I progress through the build... I'll be assembling an S14 block from the short block up. I'll include pictures and offer explanations and answers for those that ask..
What I have so far...
Assembled S14 bottomend with the following...
JE 86.5mm x 8.5:1 pistonsEagle rodsARP main, rod and head studsCosworth main and rod bearingsCosworth 1.5mm HG
Other items going into the mix...
Toda 264* 10.5mm IN/EX cams with NVCS Supertech DVSTomei RASNew timing equipNew oil pump and pickupCrank Scraper and Windage tray
I'll eventually add an oil cooler setup, and other miscellaneous items to protect my investment.... I'm shooting for a measly 400rwhp on a GT2871r .64 but building the block to hold more for longetivity and possible upgrades in the future (i.e. GT3071R TS)...
Now for some pictures of the bottomend...
***Update*** 11/1/08
I had some time to work on the engine today, got the timing guides in and the chain resting there. Also installed the ARP head studs and set the cosworth on the block. I'm waiting for the new oil pump to get here so I can put that on and trq down the head...
I'm debating whether or not to clay the engine, to see just how close my pistons are going to come to the valves... It's just alot of work to do it.
Pictures!!!
***Update*** 11/11/08
Installed the head and got it torqued down tonight. It's coming along smoothly so far, knock on wood. I've yet to order a few things, need rear main seal, water pump, thermostat, along with other misc items. I'm waiting for my crank scraper and windage tray to get here. I'll have to modify the upper oil pan so that the pan isn't hitting the scraper in the 4th bay. So far I'm happy, next one I should have the lifters, rockers, cams and scraper in...
Pictures!!!
In this picture you can see the slight port and polish I have on the intake side of the head...
Enjoy...!
Modified by jr_ss at 5:33 PM 11/1/2008
Modified by jr_ss at 10:31 PM 11/11/2008
