boost_boy wrote:In case anyne didn't know already, the CA's oil pick-up can handle a dented oil pan. It's design gives you a margin for error. Here's a pic in case anyone's wondering. You can either use a CA18DE's unit off a pulsar or KA24 (I forget which year). Just keep oil in your engine and you should be fine.
I was kinda thinking that myself.. thats a deep sump pan and the pics of the pickup tube didn't look like it fully reached the depths.. the SR has more of a shallow "flat" design and the pickup tube drops almost down to the bottom of the pan. I had to hammer some pretty nasty dents out of my lil' bro's SR lower pan when he ran a little off the road...
My suggestion is to lay the pan on a solid piece of wood or something w/ a few towels between the pan and wood to somewhat soften the blows (similar to how a panel beater forms a panel on a bag).. on a deep pan like the CA you might have to use a flat block or something and hammer on the end of it or maybe something like a seal driver.. since it'd be hard to get a rubber mallet to strike down in there... oh if your ballsy you can always heat it a little before but BE CAREFUL.. it will soften the metal and a wrong blow could crack or damage the pan beyond saving.
Oh anyways.. nice motorset
Sucks the shippers tossed it about a little... looks clean though. Hmmm where are you guys getting clips/motorsets from that seem to have pretty good service/rep...
