Jookmasta's pics
nissanfanatic
Car: 1992 Nissan 240sx SE
Jookmasta couldn't get these to link so I posted them up for him.
Interior shotInterior shot part IIThe lowness of my cold pipeTurbo/mani shotIntercooler shotPower steering reservoir near distributorTurbo intake and Power steeringManifold and Hot pipeHot side of engineBattery side of engineCold pipe side of engine bay
Modified by nissanfanatic at 9:06 PM 3/30/2005
240SicknessX
Car: 96 240 SE
ive worked with jookmasta on this project and all i have to say is he has the cleanest s13 coupe ive seen.
Jookmasta
240sicknessx and willfastbackse share part of the glory for the setup as they helped me ALOT with this setup. Much thanks to nissanfanatic for posting these pics cuz after being on this forum for a couple of years, i still dont know how to post pics.lol.
Anyways...........to the goodies:
Straight T3 fully rebuilt off of a ThunderbirdSpecs: 60 trim compressor, .63 A/R exhaust housing, internally wastegated Custom JGS manifold (i think)FMIC (custom) ~ 30 (or 33) x 2 x 7 (or 7.5)Custom 2.5" intercooler piping (i kept the stock sized battery!!!!!!!!!!!!!!)Custom 2.5"-3" DPBRM 3" dual tip exhaustNo CatBlocked off EGRGreddy Type S BOVEbay air filterSr 370cc injectors (flow tested and cleaned by fuel injector clinic)New 300zx TT fuel pump (its a 94 pump b/c supposedly 94 and 95 pumps flowed more fuel ~ could b a rumor)SAFC oneBlitz DTTAutometer Carbon Fiber Mechanical oil pressure gauge, A/F gauge, and voltmeterSS oil feed lineHeater hose return lineNGK V power - BRK-6E gapped at .30 across the boardACT Street Clutch Kit (good for like 280hp i think)Compression: 180 across the boardStock WiresBase Timing retarded to 13 or 14
Modified by Jookmasta at 5:34 AM 3/31/2005
Jookmasta
First off, let me address my biggest issue with my setup. This is my power steering reservoir. i am open to any suggestions as to where to place this without redoing the hotpipe. Its my fault for not bolting it back up before taking the car to the muffler shop but what to do with it?
MarkEmark
Car: fully-built '95 240sx KA-T
Jookmasta wrote:240sicknessx and willfastbackse share part of the glory for the setup as they helped me ALOT with this setup. Much thanks to nissanfanatic for posting these pics cuz after being on this forum for a couple of years, i still dont know how to post pics.lol.
13 deg btdc?!? How much boost are you running? That seems very conservative....When I was running like 7 psi before my JWT set up I barely had the timing retarded and it ran like a champ. The problem with retarded timing is that you WILL get obnoxious low rpm hesitation....it just feels so sluggish. It's amazing what advancing your timing even 2 degrees can do to the overall feel of the power delivery.
Jookmasta
we did the retarding of the timing so drastically due to the internal wastegate thats on the turbo. first off, the way that it is set at now, i get boost around 4000 rpms and i boost 9 to 10 psi. Now if i move my wastegate rod to the other position, my swingvalve is completely closed and i get boost around 2000 rpms. Unfortunately, or maybe fortunately, when the swingvalve is at this position, i boost one bar. Now at that power level, the timing HAS to be retarded to where it is right now. I normally run around with the turbo at the nine psi setting but i dont mind the lack of power around town. The engine still feels strong around town, but i guess it could be quicker with some more timing. Better safe than sorry tho........
Ligouri Rd
Car: '96 Nissan 240SX
I see you still have the battery in the stock position. Could you take another shot from directly above it (mabye a little behind and to the right) so that i can see how your intercooler piping is run? Thanks
PapaSmurf2k3
Site Admin
holy brown interior
Jookmasta
holy brown interior is right!!!!!!!! lol. the car on the outside is its original paint so i figure y not keep the brown and y go thru the hassle of seeing black everywhere. Plus after 10 years, the brown grows on ya...............
anyway, ill try to get pics of the cold pipe up for ya. ur battery doesnt need to be relocated, just remove the resonator that sits next to the radiator on the passenger side and u'll b golden. btw, that is a full 2.5" on the cold side.
XcreatureX
Car: 96 240sx SE
sorry i am not a fan of the brown but i like the engine setup...i cant wait to get mine started, got the turbo so far, how many psi are you running?
Seth
Jookmasta
9 psi currently; my dad has taken it 2 10 psi tho................
sil80drifter
Car: 1990 240SX Hatch
Is that a frikkin CARPETED GARAGE?!Nice steering wheel condom. No I'm serious, those are really good they make the wheel feel much better in the hand.
sil80
Jookmasta
um well my garage is kinda big, but yes my car sleeps on carpet. the other cars dont but mine does. i figure since i spent so much money on it, y not use my old dorm carpets and let her sleep comfortably. Plus i hear it extends tire life by reducing stress on the sidewalls. lmao.
turbo98_240sx
Car: computers, cars, anything that can do something and be made to do it faster stronger or better
Jookmasta wrote:First off, let me address my biggest issue with my setup. This is my power steering reservoir. i am open to any suggestions as to where to place this without redoing the hotpipe. Its my fault for not bolting it back up before taking the car to the muffler shop but what to do with it?
I have the greddy kit and what they did was just make the lines longer so that it clears the hot pipe all you need its some ruber lines that are slightly longer thats at least how I did mine I guess you could make some custom bracket but the longer lines so it fits seems to be easy and cheep all you need is ps fluid and the cost of the line
pr240sx
You can put the reservoir at the bat of the strut tower. Just extend the lines.I am very interested in the turbo manifold setup.Can you please take more pics of the hot side.
And yes, brown interior is cool!! (mine is brown too)
Jookmasta
ill get more pics up of the hotside.......
as for putting the reservoir at the bat of the strut bar, i think the lines would touch the exhaust housing of the turbo, but i will try and see if this will work. As for drilling the spot underneath the tower, will it go thru into the wheel well if i drill thru it?
