JL Audio full install in 08 G35 sedan
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
audtatious wrote:You could hang it under the package tray. Grab a threaded bar, some matching nuts and some Loctite (or more nuts to keep things snug). Measure, cut, drill, install. Just make sure there is enough space for it to breathe.
check these out...
http://www.ebay.com/itm/Jl-audio-500-1- ... 19c5e568b5
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
install is completely done! sub is placed in the trunk on pass rear. amp is installed under the rear parcel shelf out of sight. the trim under neath needed to be cut so the amp would fit, but i was not concerned. i will take pictures, but it is an awkward angle. i need to dynamat the underside of the rear parcel shelf because the pressure it the trunk makes the rear dash "flutter" on some songs with alot of bass, but overall it sounds amazing. just one 10" sub is plenty enough for me.
I had to get another LOC because the one i pictured below did not have enough output. i went one model up of the same Stinger line and it beat it's @$$ off.
other than a sound dampening material under the rear parcel shelf, i may put a set of bass blockers on the mids in the doors. i am very happy with all the work i did previously to get the rattles out because it sounds solid.
any questions, i am willing to help...thanks for watching this thread, if you did!
audtatious
check these out...
There ya go. :bigthumb:
audtatious
timmy0257 wrote:install is completely done! sub is placed in the trunk on pass rear. amp is installed under the rear parcel shelf out of sight. the trim under neath needed to be cut so the amp would fit, but i was not concerned. i will take pictures, but it is an awkward angle. i need to dynamat the underside of the rear parcel shelf because the pressure it the trunk makes the rear dash "flutter" on some songs with alot of bass, but overall it sounds amazing. just one 10" sub is plenty enough for me.
Good deal. To stop the parcel shelf from fluttering you can always use some expanding foam. In my Maxima I simply pulled the grille from the Bose Sub and used pieces of foam to brace the panel more. Worked like a champ.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
well as you can see, it took me two whole months to get all this done, so i will take my time to figure out the best way to do it.
audtatious
Understood.
I assume you removed the factory Bose sub? I remember leaving the factory sub in the Maxima and it would flutter with the bass.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
i actually do not have Bose. if i did, installation would have been easier, as I could have tapped into the wires on the factory amp.
I am running power to the mid range 6.5" in the doors via the headunit and it sounds great. i have a mono amp for the sub.
audtatious
Gotcha....
Both mine have Bose and the 10" mid woofers in the doors. The sedan sounds OK but the coupe sounds good enough for me to not upgrade.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
sorry i have not posted here in a while. everything has been installed and i placed the amp right where joe mentioned. everything is perfect. the liner had to be trimmed but no big deal. concealed and perfect.
thanks!
joe603
Car: 2014 Durango R/T
Lets see some pics!
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
i can take some soon. there is not really much to see, because the amp is concealed. i will get some up soon.
Guju Rider
Car: 2004 Infiniti G35 Desert Platinum (Sedan)
Looks like you have a great set up timmy0257. I have a question though since you're using the JL TR650-CXI speakers.
I have a 2004 G35 sedan with Bose (or Blose as some people say). I also have upgraded the headunit to an Eclipse 52D. I do have a 10w3 powered by a JX500/1, which is great for me since I do not want to be heard coming down the street.
1) Would factory Bose amp be to power the TR650's if I was do change out my door speakers?
2) Is the process a direct swap out besides adding the spacers? (plug-n-play)
Actually, anyone can help answer this question.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Good question and I would say yes. Just remoe old speakers and replace with new ones. You may a need to crimp connectors on the end and affix the spacers
audtatious
While it would work you would lose volume. Most Bose speakers are 2ohm other than the tweeters which are 4. Running 4ohm speakers instead of 2 means you lose 3db plus some headroom.
joe603
Concur with Matt on the 2ohm speakers in a Bose system.
macdonjh
Car: 2004 Infiniti G35 coupe
Rats, all the photos are gone!
Return to “G35 and G37 Interior, Exterior and Audio”
