JISMO transmission mounts
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Okay, so my transmission mount was totally shot and I coudn't stand the sloppy feeling shifts anymore. Unfortunalty I am totally broke right now, no money for a good transmission mount and I don't want to buy a stock one and replace it later.
Solution: Solid Transmission mount.
I unbolted the old mount, the rubber was already cracked in half so it was no problem to remove the metal bottom part from the top. Next I removed all the old rubber with a angle grinder and coarse pads. (Yeah for air tools). I welded in a piece of 1 inch square tube (Yeah for POS flux core welder) to replace the stock rubber and reinstalled it all.
Total cost $0
I have never felt a car vibrate so much. It is like you can hear the gears in the transmission grinding together and I can hear every noise the engine makes. I have nothing but a huge grin on my face. I can't wait until my wife gets in for the first time. She is gonna ****! It's cool for now but I will see how long it lasts on a daily driver.
If you have the tools, mainly a welder, this was one of the easiet things I have done to my car. It took about 1.5 hours including a long test drive.
WDRacing
Try solid motor mounts along with the transmission...talk about a ruff ride.
steve s14
with the engine mounts being stock and the trans solidly mounted, it may crack the trans cross member from the flexing loads.i wouldn't recommend leaving it like that for a long time.cool writeup though!
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
steve s14 wrote:with the engine mounts being stock and the trans solidly mounted, it may crack the trans cross member from the flexing loads.i wouldn't recommend leaving it like that for a long time.cool writeup though!
Interesting, I plan on making motor mounts from hockey pucks pretty soon. Those should be close to solid.
Craving4Boost
Car: 91 240sx fastback
anyone have a video inside a car with solid mounts? i want to get an idea of how its like.
naed240sx
Car: .....
LEMHEAD16 wrote:Okay, so my transmission mount was totally shot and I coudn't stand the sloppy feeling shifts anymore. Unfortunalty I am totally broke right now, no money for a good transmission mount and I don't want to buy a stock one and replace it later.
Total cost $0
I can't support this fact myself, but intuition seems to support it. I have heard that a solid mount is very bad for transmission life, and causes unneeded strain on the gears. I suggest picking up some new oem mounts.
