Jim Wolf Technology Light Weight Flywheel
ny infini g
Car: 2005 G35 coupe
whats going on everyone .. anyone have the JWT light weight flywheel ?? could you tell me what some of your experiences were with it or if you heard anything out that particular product
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
With the JWT flywheel you will probably dislike the noise. The lighter the flywheel in any VQ series the more gear noise you are going to hear at idle and up to about 2000 rpm. I have the ACT street lite and the noise is not that bad, it is 16.9lbs vs jwt 13lbs comparing both to oem @ 24lbs. Acceleration is definitely improved and the engine revs quicker. The only issue I had at first was the idle. Had to have it bumped up to around 850 because when I pushed in the clutch the revs dropped down so fast the engine acted if it wanted to stall. The 850 rpm resolved that issue.
SavG35
Car: 2004 Infiniti G35 Coupe
Let me know what you choose to got with. I'm looking into getting a new lighter flywheel as well right now, and would love to hear what you choose and how it works for you.
RED_DET
Vendor
2011 Infiniti G37x
Well after cracking her open for the first time today after the engine/clutch break-in, I'm in love.
SavG35
cool did you install it yourself or have it installed??? if you had it installed how much was it? I got a quote from a local store for around 440 and I was wondering if it is super far off or not
RED_DET
Vendor
2011 Infiniti G37x
Luckily, I got mine installed when Infiniti had to replace the engine under warranty. I have a good relationship with the guys over there, so they didn't charge me extra, but slipped the tech some money on the side. $400 doesn't sound to bad, as they have to drop the transmission and all.
