Aaron_9349 »
https://forums.nicoclub.com/aaron-9349-u14669.html
Tue Jun 21, 2005 9:19 pm
Ok, I know theres been some talk about using the DSM resistor box to lower the impedeance for low impedeance injectors. What I was wondering is if anyone has used the Jim Wolf resistors. I'm sure plenty of people have the ECU's and such.
They seem to be in-line resistors, I'm assuming you wire them in directly before the injectors. If not, then where. I'm also assuming that these would eliminate the hassle of routing wires to a seperate box, mounting the box, and then to the injectors if this is true.
If anyone's got some info on these that would be great. Thanks
