Jim wolf Ecu
tutiracing
hi i have a sr20det redtop, 4 bobins, dis. I bought an ecu programmed by Jim Wolf , with a Ford Cobra 1994 maf, 555 cc injectors. I have the Super Afc installed, but i cant find the settings (ecu number and maf) to continue programming the afc. If someone knos how please tell me
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
If I am reading correctly and the ECU is already tuned for afore mentioned set up, then the AFC is pointless.
codyace
Car: S14 w/redtop
The last thing the ECU needs is the AFC. Throw that thing in the trash, and go from there. Put your car on the dyno, check the air/fuel, and globally correct using the FPR (although they are all setup to be set at 3 bar without vacuum/wot).
The biggest things to keep in mind are:
1. Make sure timing is right2. make sure no vacuum/pipe leaks
tutiracing
Thanks for the answer, but i have been told that i can install the super afc with the jim wolf ecu.But i dont know how to get inside the jim wolf program and install the super afc. I need to install this because in my Country, all cars need to past a fuel test, and without the super afc, it turns almost impossible the adjust the fuel and past the test.
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
you dont need to get inside the ecu to install the afc. You need to splice into the wiring harness.
FAST-DATSUN
SAFC is a piggy back unit and install into the wiring at the computer, NOT IN the computer. Just wire it in to the wires about 4-6 inches from the computer, However the SAFC does not have a setting for the FORD MAF so everthing will be very difficult to set up....
dbrass240
Car: 89 hatch wit de sr
safc = waste of money
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
he is not using it for tuning performance. It sounds as if it will just be temp to pass an emissions test
