RobertsnewQ »
https://forums.nicoclub.com/robertsnewq-u29366.html
Wed Nov 30, 2005 9:51 am
I have four or five JWT chips for the Q now, and they are all different. One is early - from 1992 or so, two are later (1995 and 1999) and one is unknown.
Their tunes become more agressive in LATER files, which is unexpected.
They raise the VTC turn-off RPM, rev limiter (7200, though, not 7300), remove the speed limiter, and as Dennis said, advance timing at high load levels. However, the advance reaches all the way down to 400RPM, petering out around 2000, and increasing again to 7000. Low-load timing stays the same on all JWT tunes I've seen.
They lean the fuel map in the higher load/rev ranges, but richen it up in the midrange. The OEM ECU has two fuel maps, a knock and a no-knock, and JWT replaces them with one (based off the OEM no-knock map).
Should be good for almost 20 HP at high RPMs, but there is room for improvement.
