hysteria wrote:i just browsed over that website you provided... very interesting... but do you know if they do/will offer anything for the ka24de? this is something i would really be interested in purchasing as i feel, like you said, that jwt is a little over priced for what it is. I would completely be interested in learning about this and then doing it myself. that is of course if they offer some compatable solution for the ka24de (i have all 1992 electonics controls and a 95 block and head, so i would be looking at a 1992 ka24de solution).
Heres a break down of what you need to know.
B13's and S13's share the EXACT same motherboard. What this means is that your ECU uses the EXACT same traces to get its information from the built in memory as the B13 SR's and S13 SR's. So, the product that your looking at on biki's site will work for the OBDI KA24DE (91-93).
Im using a B13 daughterboard on my KA and it works fine....Cost me $100 and now I have a fully reprogramalbe ECU. Dont forget though that you will also need an EPROM burner. Mine was $150, but, mine is also overkill. You can get a reputable burner for like $85 (Willems).
S14's use a different board, so its highly unlikely that this would work on them.
All said and done, modding your stock ECU with a daughterboad (exactly what JWT does only they use a single 16bit chip with scrambled code, which I have and is de-scrambled) will cost you about the same as a full E-Manage set up, or a plug and play JWT set up.
Cost break down:
$100 for a DB, $85 for a burner, $350+ for a wideband O2 <--because tuning with out one is pointless.
The beauty of it is that you will NEVER have any downtime, shipping costs, turn around, or, pay for an miscelaneous reprograming due to part upgrades like MAF/injectors/revlimit changes etc....
Modified by JRL at 8:42 AM 4/4/2005
