Post by Billgatto16 » https://forums.nicoclub.com/billgatto16-u274278.html Thu May 18, 2017 11:57 am
Post by telcoman » https://forums.nicoclub.com/telcoman-u43180.html Fri May 19, 2017 5:52 am
Yes you learned a painful lesson.Billgatto16 wrote:so after i pick my g35 up from the transmission shop, the tech tells me to get the radiator flushed out. so next door is a jiffylube and 99% of the times i don't let them work on my cars and i was just given a painful reminder as why. after driving away and getting on the highway the temp needle slowly rises to the h mark and i pull the car over to the side of the road. after inspecting under the hood i notice not only did they not replace my reservoir tank cap but they also did not put the clamp back onto the upper radiator hose causing all the antifreeze to shoot out and overheat my motor![]()
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
