Falkdesigns »
https://forums.nicoclub.com/falkdesigns-u14665.html
Tue Dec 27, 2005 8:14 am
The problem with coilovers is that if you want them done RIGHT, you have to find a race shop, or a shop that's properly equipped with SCALES. A car with coilovers needs to be corner weighted to be done RIGHT. Now, I'm sure some folks just put them on and say "it looks right", the thing is, it's not right, unless it was corner weighted. Corner weighting is where the driver sits in the car, the car is resting on 4 scales connected to a computer, and the coilovers are adjusted until all 4 corners of the car read the same weight, hence, "corner weighting".
They are great when they are done right. Personally, I rather just find springs and shocks that give the ride height I like and leave it at that. The only advantage of coilovers is being able to go up or down to your liking. The problem is that every time you change the height, you need to go back to the race shop and get it corner weighted again.
