Darius wrote:BoostsFed - I'm VERY interested in making my own rail if I can buy blank -8AN for $11/ft. Plus I could have the return line orifice sized and tapped to match my FPR line fittings and located where I want it. Can you give more details, or is it as simple as having holes drilled to match the diameter of the injectors that you plan on fitting?
To add to that, how did you fasten your rail to the intake manifold?
it's as simple as drilling the rail to port match the injectors. measure carefully, make sure it's smaller than the O-Ring, so it can seal better. also make sure your drill press is stable and drill straight. look at any top-mount fuel rail and you'll see it's just a straight through. as far as mounting goes, the lower part of the fuel rail are solid, you can drill and tap any holes for the mounting bracket. then tap both ends and put in your favorite fitting for the feed and return lines. i will try to get some pictures posted when i get my digital camera back from a friend.
